The past couple of months i've noticed a new noise in the truck. It has 170,000 miles on it, and I bought it with 120,000 miles on it. The noise is loudest when the engine is cold and seems to go away when it warms up. it sounds like gear noise. You can't hear it at idle, but when you rev it up while sitting in the cab you can hear it at all rpms off idle. It makes the noise while increasing and decreasing rpm. It does it with the trans in neutral or in gear. With the clutch pedal up or down. I don't think it's the transmission. It runs the same as always, and I've checked the oil for metal and haven't found any. Something else happend about the same time though. the oil pressure gauge used to work off the oil pressure. Now it will climb to 90 psi with just the key on engine off. It never did that before. It works more like a switch than a gauge. I've never had it reflashed, so why would it do this? as far as the gear noise, could it be the p/s pump-acc drive? ANY HELP would be nice. I know new noise's aren't usually a good thing. Thanks.
