Gear Oil for NV5600 question
DC's Definition of Service?!
Some pictures of my truck!
I've been trying to locate a 5 gallon bucket of Texaco 1874 MTX gear oil for the NV5600 6 speed transmission. I can't seem to find it anywhere. Does anyone know where I can buy 5 gallons? I would prefer NOT to buy the quart size bottles from DC since they are like 20. 00 a quart. Do you know if they are any cheaper from GM?
Thanks in advance,
Charles
2000 QC 2500 4x4 LWB ETC/DEE, Anti-Spin, 3. 54, Trailer Tow, Camper Special, DD1's, PS boost module, PS high idle kit, PS steel idler pulley, Westin nerf bars, Rhino Liner
My Toy
1969 Toyota Land Cruiser FJ40
350 TBI, Turbo 400, ARB lockers front/rear, 4 wheel power disk brakes, 4. 88 ring/pinion, 3 speed transfer case, full roll cage, Warn 8274, MRT 36 bolt beadlocks with Super Swamper Boggers (16x35x15), Saginaw Power steering, custom bumpers/fenders/nerf bars/skid plate, GM tilt steering column, 6 point roll cage, RCI racing seats with 5 point harness. Conquered Tellico and going to Moab this May. Loves to be pulled behind the Dodge and pass the powerjokes going up hills.
Try "Cummins" if you have one close by or any big rig supply company.
[This message has been edited by Tom C (edited 04-21-2001). ]
Your local Dodge dealer should be selling the NV5600 fluid for $10. 50 a quart plus tax. That came right out of the dealers book last week. It is also the fluid for the NV 3500 transmission also... ... ... Pete
I read on this board, and was also told by my local distributor that Texaco is no longer selling this product in the 5 gallon pail. I'm guessing it was low volume, and/or DC and GM asked Texaco to quit undercutting them. Locally, it was about $1 cheaper per quart purchased from GM.
Those organizing rallies should add one new event: Someone buys a 55 gallon drum of MTX 1874, and sells this stuff for ~$3 per quart, bring your own container!
I'll take some. Can't find it anywhere but the Dealer #ad
FDz
Frank Dziurda - K7SFN
Carson City, Nevada
'99. 5 2500 4X4 6-Speed Quad Cab LWB 3. 54 LSD
Does anybody know what synthetic is being sold by DC for us that do a lot of heavy towing? I understand there is a MOPAR number but since they don't manufacturer synthetic, I don't think, I would like to find the same kind they use for both NV5600 trans and limited slip rear end. If all else fails I guess I go with AMSOIL. Like to find this stuff cheaper without having to rob a bank!!! #ad
2001 RAM 3500 dually Quad Cab SLT, 4. 10 limited slip, HO 245 hp, 6-speed, dark garnet pearl coat, interior agate, All options except heated leather, added DeeZee brite diamond tool box, Linex spray-in bed liner, Lund hood deflector 3 piece smoke color, DeeZee brite diamond cab/bed running boards and TurboSaver (from Gino's) also Reese 5th wheel 15k hitch. No plans to bomb. This is my retirment vehicle currently pulling 21' 5er want to buy 30 to 35 for retirment.
FJ40,
I went thru this back in February. You're correct, Dodge dealers wanted $20+ per quart. Some Texaco distributors claim they can not get the MTX in 5 gallon pails. I found 2 local distributors that were able to order it. Came in within 3 weeks. Price was approximately $8. 70 PER GALLON, so total cost for a 5 gallon pail was right around $50. 00. You should be able to call up the Texaco website, and find some local distributors close to you. Just start callin'.
THERE IS A CHEAPER SOLUTION THAN DODGE !
2001 ordered 12/20/99. Arrived 2/9/00 2500 RC, SLT,4X4,ETH,6-speed,4:10 anti-spin,Camper special,cab clearance lights,GPD trailer tow mirrors,sliding rear window,Snow Plow prep, power seat,Line-X'd OTR bed and quarter panels,DeeZee running boards,INTENSE Blue/ agate.
I looked in the yellow pages and found a Texaco distributor listed, it in Winchester VA. They didn't stock it but orderd it and was in a week later, $49. 00. They wouldn't deliver since I didn't have an account so had to drive 110 miles each way to pick it up.
Larry
Ram Rod
'01 3500 white quad cab sport 4x4 ETH DEE SLT+ 4:10s posi Pac brake combo gauge tow/camper pkg. 20k reese 5th hitch
35' holiday rambler 5th wheel
Okay, one more time,,,,Part number-4874464 is for the NV 5600 and the NV 3500 trannys in Dodge trucks... . It is $10. 50 at YOUR local Dodge dealer..... Pete
The NV600 xmsn in my truck had two tags on it stating that if any gear oil other than Mopar 4874464 or the Texaco equivalent were used I would void my warranty. I asked the head mechanic at the dealership I bought the truck and he said the 4874464 was a synthetic oil. The 4874464 I put in my NV5600 said on the bottles it was made from petroleum distillates. That's not synthetic. Also saw here that only the MOPAR 4874464 has the carrect blend for proper operation of the NV5600 synchromesh gears. I paid $8. 00 a quart at the dealer.
2001 Patriot Blue DRW lmslip ETH DEE. Xmsn/Dif temp, Boost/EGT, Xmsn Filter, MagHytec diff w/synthetic. 9. 5', 91 Sunline camper (Home). GVW 10800. 5800 miles mpg @ 60 mph 15 (& climbing) around town mpg 13-14. Gauge readings @60 mph I 10 Fla, 70 degrees outside temp. Boost-8 , EGT 750, Xmsn-175, Diff-145. (Diff runs 25-40 degrees cooler than Xmsn depending on outside air temp.
Pete,
Maybe at YOUR Dodge dealer it was $10. 50 a quart, but at MY dealer, they wanted $20. 00+ a quart, but what's the difference, you can still get it from a Texaco distributor for $10. 00 a GALLON. In any case, Dodge is still ripping everyone off, just some dealers maybe more than others. . And yes, that is the correct Mopar part # for the fluid.
For anyone interested, or chemists in the group... .
On the Texaco pail the product code is 1874. The label also shows "MTX FLUID 12550"
It is considered hazardous, by OSHA
The product chemical names and percent are;
dewaxed heavy paraffinic petroleum distillates 65-79. 99%
benzene 10-19. 99%
methacrylic acid 3- 9. 99%
hydrotreated heavy paraffinic pertoleum
distillates 3- 9. 99%
solvent-refined light naphthenic petroleum distillate 1- 2. 99%
sulfonic acids,petroleum,magnesium salts
1- 2. 99%
All it takes is a few changes, or another friend with a 6-speed to make it worthwhile to purchase by the pail.
I think it might be worthwhile for local TDR members in a city to pitch in an purchase a 55 gallon drum and split it up. The 5 gallon size is discontinued. I heard DC and GM were complaining about to Texaco about undercutting their profit margins. On the 5 gallon pail there is a writing that says, "Restricted product to GM. "
I was lucky enough to find a 5 gallon bucket from a fellow TDR member who happen to have ordered it for his NV4500 and realized it would not work.
Charles
My Toy
