I run 63-64 at 2000 RPM's towing the 5er with 4:10's which is the sweet spot for 24V.
Repeat:
24V - Towing - Hills - Auto = 4:10's
It is "not" a freeway high speed cruiser. It will do it, but it wears you out with the higher RPMs and noise.
Without more gears it is a little hard to have a warranty and both good towing and high speed cruising at the same time without doing the shifting yourself.
Believe it or NOT, not everyone wants to bomb their truck. Flame away!
If the Std Cab I found last June would have had a 6 speed, then I would probably have a manual, wife does not drive it anyway.
SNOKING
