2nd Gen Non-Engine/Transmission gear selector indicator
Engine/Transmission (1998.5 - 2002) Another p-o216 code
I don't know if your indicator is the same as my '95. On mine there is a little lever that is on the steering column. It has a little cable loop on it. You have to remove the bottom cover of the column to get to it. The lever is easy to bend. If you have been doing any work under there the loop may not be on the lever right or the lever is bent.
