Kburgoyne,
I don’t have a GearVendors unit, but years ago I installed a U. S. Gear overdrive on my 2000 model year truck. I wrote an article for the TDR that was published in issue #47, page 162. I would recommend you read that, since it’s much more detailed than what I can write here.
Here are some of my thoughts:
I went with the U. S. Gear instead of the GearVendors mostly because the U. S. Gear unit will work in 4WD. The GV mounts to the rear of the transfer case and does not change the ratio to the front drive shaft, so it is locked out whenever you are in 4WD.
I also wanted the manual shift of the U. S. Gear unit, although I’ll admit that I have never driven a GV.
As I said in that article, an overdrive installed on a five-speed transmission is probably a much better investment than converting the truck to a six-speed.
At the time I wrote that article, diesel fuel was selling for about $1. 70/gallon. (Oh, for those prices again. ) With that price for fuel, the savings in fuel cost would essentially never pay for the cost of an overdrive unit. If you put on really high mileage, like over 30,000 miles/year, you may save money, even at today’s fuel prices.
I really liked my overdrive and considered it to be the best accessory I added to that truck, with the exception of the exhaust brake. I would encourage you to do it.
– Loren
