So here I am in Colorado, here on business for three weeks. Being the autocrosser type, I chose to drive out and tow my car. The truck is a 96 RAM 3500 CC 4x2 with automatic and 3. 54 gears. It has the TST #5 (280/680) plate centered, AFC housing all the way forward, and the 16cm2 housing. I also have the BD extra low stall converter and valvebody. Truck recently dynoed 242 hp and 617 lbs-ft at the wheels.
I carry a Lance 1030 camper and tow an '86 Corvette on an open trailer. Total GCWR on the way out was 18,060 lbs as determined by a Flying J truck scale.
My first observation is that I think I need to go to 4. 10 gears. Going up many hills, still at only half throttle in 4th, I had to let it lose speed and eventually drop into third and hold about 50-55 mph, with the RPMs at or above 2000, to keep the EGTs in check. I was still consistently holding at 1300 deg, and as the elevations got higher, it got consistantly worse.
It got to the point that while canyon-carving in eastern Utah on I-70, going DOWNHILL slightly (on the throttle, not on the brakes), the best I could do was 60 mph at 1200-1300 deg. in 4th. I could drop to third and get it a little cooler, but then I was still suck at the same speed. The road was very capable of supporting 70+ (as was the speed limit of 70-75). I just couldn't do it.
The tires are 225/70-19. 5's, so they're quite a bit taller than my stock 215/85-16's. This is part of the problem, since it's made my 3. 54 an effective 3. 23 or something like that.
Add to that the fact that the transmission is a POS. Once high enough, and with the hot weather (90+ deg), the thing didn't want to downshift below 3rd gear without flooring it or shifting manually (during stop and go traffic in Salt Lake City). Also, leaving from a standstill took absolutely forever.
I've come to the conclusion that I need one or more of the following:
- 4. 10 gears
- a conversion to a 5 or 6 speed transmission
- a Gear Vendors splitter
- a new truck
So I'm thinking... the quick and easy solution is to do 4. 10's, maybe even before I head home at the end of the month. Still, I could end up with a dead transmission by the time I get home, dunno.
If I keep the truck, I'd want to add to the 4. 10 setup a GV box, but that's like $3000 installed.
So then I wonder if that $3k (plus the $500 or so installation of the new gears) wouldn' be better spent as down payment on a 2001 ETH 6sp RAM (or, dare I suggest it, an Allison-equipped Duramax Chevy with a CREW CAB).
Thoughts?
Rob
- 4. 10 gears
- a new truck
Thoughts?
Rob
