US Gear underdrive
I have been using the US Gear underdrive for over 50,000 miles and love it. It works great pulling up hill or being pushed down hill. It clunks when you shift it, but there are no clutches to wear out either.
Gear Vendors does not make and underdrive unit (i. e. the output shaft turning slower than the input shaft). They only make an overdrive unit (i. e. the output shaft turns faster then the input shaft). It is strickly a marketing ploy when they say overdrive/underdrive.
I have talked with two motorhome owners who had Gear Vendor units installed. Both had them removed after about 30,000 miles because they started to slip. The motorhomes had gcwr around 25K to 30K pounds.
