2nd Gen Non-Engine/Transmission GEN Light in Dash on 96
Engine/Transmission (1994 - 1998) Sweet Spot?
Engine/Transmission (1998.5 - 2002) Problems with DTT
Hey guys,
I don't have the owner's manual for this truck I bought but its a 96 2500 4x4 Cummins 12 valve, and a red GEN lit up under the speedometer. Can anyone tell me what this means? Is it important? Does it mean My engine stepped up from a gen 2 to a gen 3?!
Thanks
Andy
What does the voltmeter read? If it is around 8v or so, may be a blown 120 amp fuse in the PDC under the hood. Held in place with 2 screws.
It means you are having trouble with the chagring system.
You can check out the asd relay.
The battey tempature sensor/connector/wiring (located under neath driver's side battery tray).
Engine speed sensor connector/wirring (dirty or bent/loose pins)
Thanks guys, I'll check it tomorrow morning. I figured it was something electrical (hence GEN), but my volts are great according to the guage. I'll check under the dash and hood tomorrow. Once again, thank-you.
