My truck will not hold a charge, it will only start with a jump start after 5-10 minutes of charging time.
After driving the voltmeter slowly drops w/ no stero on.
rapidly drops with headlights on.
I have posted a thread last month and determined the PCM was bad, bought one from TDR member and that fixed the A/C, and idiot lights.
But now after voltmeter drops below red line (10 volts?) the GEN light comes on
With battery charger hooked up I can sit in drivers seat with truck running and plug in battery charger and watch voltmeter climb to 12 or 13 volts and GEN light goes off.
Then I unplug battery charger and the voltmeter drops down and GEN light comes back on.
Finally the QUESTION:
Should I replace the altenator?
I can't find the ground strap that goes from the engine block to the frame where is it?
Thank you very much for the help
