Engine/Transmission (1994 - 1998) ?+#$@%# Gen light on help....
Engine/Transmission (1998.5 - 2002) EDGE EZ and Snow Plowing
Engine/Transmission (1994 - 1998) jig in oregon?
The GEN light just came on. :( The belt is still on and the battery terminals are tight and clean. Time for a new generator?
Thanks
Brian
Check the alternator voltage. They either work or they don't. Make sure your manifold heaters are not stuck on - gently grab (one at a time) the wires going to the manifold heater with the engine running. If they are hot, disconnect them.
Same exact thing happened to me on New Year's Eve. Had to get a new alternator - luckily my mechanic could get me in and out in one day. He said 175,000 miles on one alternator was pretty darn good.
Valarie
I just now finished replacing mine, $110 +$60 core charge. Only took ~3 hours and the hardest part was getting the pulley off the old unit.
Valarie, mines got 174,860 miles on it, maybe this is a scheduled maint item?? :rolleyes:
FWIW, i used a propane torch to heat the nut that holds the pulley on the old alternator, put a 7/8" socket over the big nut and gripped it with 2 pairs of vise grips. thru the center of the socket i had a socket and extension on the smaller stud the big nut threads onto. It was pain to break it loose but i got it.
The truck is happy again... . :cool:
Brian
Not true. Mine was working ,but only at arround 60%. I was getting an intermittent check engine lite for a couple weeks. Autozone tested it,condemned it, and changed the pulley for free ;) ... Problem gone
Check your 120 amp fuse under the hood in the PDC. BTW, the voltage is controlled by the PCM. Not an internal regulator.
Have you been anywhere near the PCM? Check those connections as well (Pass side fire wall).
Edit: Does the tach work?
