2nd Gen Non-Engine/Transmission gen light on
Engine/Transmission (1998.5 - 2002) Fass Instal
Engine/Transmission (1994 - 1998) Clutch problem
on the way to work this morning the gen light came on the volt meter showed just over 14 and slowly dropped for about 5 miles when the volts got down to the bottom of the normal range it popped back up to 14 and started this cycle over all the time the gen light was on. has anyone seen this before? 97 2500 4x4 auto all stock 140,000 mi.
Never seen that happen, but could be the regulator on the alternator. I'd get it in and get it checked. If it has an external regulator, you may want to have it tested and possibly replaced. Sometimes the regulator will fail and then start doing very strange things...
