I was wondering what you Gen3 guys get for stock pressure from the stock lift pump?
Thanks,
Matt
Thanks,
Matt
bpenrod said:I didn't like it either so I got rid of the stock lift pump. On the other hand I think that falls within spec and was working properly. Now I have 18 at 1idle and can only pull it down to 14 or 15 at WOT. I'm not sure if that is too far the other way so I'm going to put a lighter spring in it and hope for the happy middle!!
rbattelle said:8-9 may seem low, but with a CP-3 it's really flow rate that counts. Factory minimum spec is 38 gph. The CP-3 has an internal gearotor pump so inlet pressure isn't so much of a concern as it was with a VP-44.
-Ryan![]()
