2nd Gen Non-Engine/Transmission General Suspension Concerns
Engine/Transmission (1994 - 1998) piers turbo on ebay
My Ram passed 100k miles a couple of months, ago, and I've noticed a gradual degradation in the ride quality during the past year or so.
I can't point to anything specific, and the truck still tracks very well going down the road, but, overall, there are noticeable differences in the "driving experience" from when the truck was new. I've also noticed a little bit of "fletching" on the inner edges of front tires, though really very minor, and typically corrected by rotating tires to the rear every 5,000 miles
I'd like to spend some money getting things "buttoned up," but don't know where to start. I'm reluctant to go to the dealer and say, "Hey, will you check the suspension components, and replace whatever is worn," because I know that would break the bank-even with a reputable, honest dealership.
I've always been careful about maintenance, and replaced some of the components, early on, at the recommendation of TDR writers such as Scott Dagliesh. Mopar steering dampeners, shocks, and suspension arms were refitted with the Rancho upgrades at about 50,000 miles, and I noticed a terrific improvement.
I'm noticing more front end noise than usual, mostly when driving over "washboard" sections of pavement. The service manual states, "Tighten of replace components as necessary," and that's where I could use some guidance from owners who've been down this "road" before.
I had a major brake job done about 5,000 miles ago, and virtually everything was replaced including wheels, rotors, calipers, pads, drums etc. , at that time. The mechanic who worked on the truck didn't mention anything about worn steering/suspension components, but there has to be considerable wear on a truck with this much mileage on it.
Anyone who has any thoughts on where to start, how to look for obvious signs of wear, and what logical steps should be taken in replacing worn parts, would be greatly appreciated.
Sasquatch,
I didn't see anything in your post about a replacement tracbar. If it's the original in your truck I'd replace it without even having it checked. Biggest steering improvement I made to my truck was the DT tracbar. Second thing I'd do is find a shop I trust that has experience doing front end work and have them check the suspension and steering componants.
Dane—
Thanks, man.
That's the funny thing, though. My steering seems to be very good. It wasn't up to snuff when the truck was new, but the dealership performed the steering box adjustments (tightened thrust bearing, etc. ), and they replaced the intermediate steering shaft with a new, heavy-duty one. After the new Rancho stuff, the truck has really driven and steered pretty darned well. I have fairly wide, aggressive tires (BFG 285/75/16 AT), so I know this truck's never going to drive like a Mercedes.
The main irritation is the related rattling noises—almost like a low-register "rumbling"—that occurs when crossing areas of rough pavement. I don't notice anything on the highway, or when on smoothly paved surface streets. It's just when I drive over areas of broken pavement, hit a pothole, etc.
It's more noticeable, now, I'm sure, because I just spent time eliminating (with TDR member help) the louder than hell "4x4 shifter buzz" that has plagued this truck since it was new. Now that the cab is quiet, I'm hearing all kinds of strange stuff I never heard before. :)
I'm sure I'll eventually take your good advice, and hunt up a good, trustworthy shop, but I thought I'd tap TDR member "input," first.
I am going to replace the track bar, too, regardless, with either your fix, or Luke's Link.
Also, I'm going to order the new, pitman arm stabilizing bracket that's being built by a Canadian TDR member, as soon as I read a little more positive input from guys who've already installed it, and driven with it for a while.
I'm not that familuar with the 4wd front ends but;
You might want to replace any rubber bushings with poly bushings. If the bushings for things like the sway bars are worn they will allow more movement and flex more than they should.
Good luck
Craig
