2nd Gen Non-Engine/Transmission Generator problem?Please help
PUMPERDUDE
I have an intermitent check engine light coming on. The code reads #41... ... ... An open or shorted condition detected in generator field control circuit... .
Voltage has started to fluctuate between 12 and 14
Questions
1) In other words is this a bad altenator?
2)Are the altenators rebuildable; Change brushes?
3)Are Autozone altenators any good?
4)What can I check at home?Go slow,I am electrically challenged. Thanks in advance.
If you haven't already, check for good solid connections at the alternator - pay close attention to how solid the wire/plug connectors are attached to see if corrosion is present. I wouldn't rule out a bad battery, either...
Just a follow up... . Had Autozone check the batteries. Both were OK... They tested the Generator @ 2000 rpms it would only put out 45 amps. I went home pulled the generator and inspected the brushes. They were toast as was the armeture... . 233k miles,cant complain... . Got a remanufactured one with lifetime warranty for 149+tax. Oh well,guess its good for another 200k miles;)
YUP - those Nippondenso jobbies ain't CHEAP!
At least that is what was on my '91 - haven't looked that close on my '02... Glad you at least isolated the problem...
