Geno's 3934373 Thermostat
Levelling kit for 2001 2500!
Isspro - Good initial impression!
I purchased the 3934373 Thermostat from Geno's and no where on it does it say what the degree is. Is it a 160, 180 or 190. Does anyone know? Has anyone used this and if so, how well does it work?
Thanks,
Silver Streak
:D :D :D
I have one in my truck I got it from cummins northwest.
It works well and does not fluctuate like the stock one. It seams to hold at 170-180 deg. Hard to tell on stock guage.
Jason
Thermostat
Jason, thanks for your reply. I'll have to put it in and try it and see where my temperature goes.
Silver Streak:D :D :D
96 Dodge, 12V, 5 speed, 4. 10, 230 injectors, TST Plate #5, 16cm turbo, BD3000 governor spring kit, 4" exhaust, Horton Fan Clutch, BD Exhaust Brake with 60 lb springs, Psycotty Air Filter, SouthBend Clutch, Mag-Hy-Tec Dif Cover, 300 hp, 700 lbs torque
Hey Mike,
I just had Cummins MI replace the stat in mine (too durn cold for me to do it outside!) and it indicates about 175 degrees on the gauge. They used a stat with a part number 3928499.
Don (MI)
Thermostat
DON
Not to sure on the degees of that part number you gave. Out here in so. calif it does not get that cold. I pull a 5ver and with the air on it gets a little warm about 200 degees and more.
MIKE:D :D :D
