I don't know if I got a bad one or, [insert deity here] forbid, my torque wrench is bad, but I snapped it off inside the head. Torque wrench set to 12 ft-lbs, everything nice and clean/lubed.
It broke about 1/4" below the nut's shoulder, leaving about 3/4" in the head. It came out very easily with a #2 extractor, with no additional drilling.
I was trying to use the bolt that's in-line with the rear of the fuel filter (yes, I was using the one closest to the valve cover). I don't believe I bottomed out, because a piece of wire inserted through the hole in the bolt went down about 1 inch below the bolt's end.
I ended up using the plugged location behind the fuel filter. I already had the reducing bushings, and didn't feel like tapping the air horn.
Has anybody else had a similar problem? Or should I toss the torque wrench?
