Two questions:
First do the mirror extensios from Geno's snap on and off or do you attach them permanently. Second for you guy's running synthitic oils where do you get the oil analysis' done and what do they normally run in cost also do most of you just change filters and top off the level if the report is good and how long do you go before changing plus is 67,000 miles to late to change to synthitics.
Thanks,
Paul
'96 2500 ext. cab, LB, 4x4, 5 speed, 3. 54, TST 280 cam plate, AFC spring kit ,pyro and boost gauges mounted on A-Pillar
Thanks,
Paul
