Genuine Mopar Fluid 68048953AB Antifreeze/Coolant
Need Help With Engine Output/Transmission Variations
Must have raised the boy right!
Is Genuine Mopar Fluid 68048953AB Antifreeze/Coolant pre-mixed 50/50 or full strength ? Dodge parts person tells me its pre mixed but nothing on the container can confirm this.
Thanks.
2011 3500 6.7
This is the coolant specified for the truck in your sig, 1 Gallon - 05066386AA and should be concentrate.
bpep, be thankful you have the 2011 coolant. I just checked on my 2013 before a trip and the new and improved for 2013 coolant was about $50 a gallon according to my dealer here in Surprise Az.
Apparently for 2013 its a "OAT" not HOAT type coolant as before....:)
Yes , according to Starparts Chrysler the 68048953aa is full concentration and the 68051212ab is a 50/50 mix and clearly shows it on the container. They both have the same part number MS-9769g. I think the 05066386aa that sag2 is suggesting is an older stock code.
I'm going with the 68048953aa and will mix it water.
Thanks
Careful guys. Don't put out misinformation. 68193849 is pre mixed coolant for 2013 and later engines that use MS-12106 spec coolant (10 year/150,000 mile coolant). It is OAT coolant. 68048953 is concentrate for 2003-2012 engines utilizing spec MS-9769G coolant and is HOAT coolant (5 year/100,000 mile coolant). You can mix them, but you destroy the newer coolant's 150K mile change interval if you do. Yes the new coolant is more costly, but how often do you want to change it out in your truck? Ken Irwin
Thanks
Sorry, I didn't check the supersedence before I posted. The specified coolant 05066386AA is now superseded to 68048953AA.
