After 275,000 miles of routine oil changes, the Getrag went to the transmission shop. The symptoms were:
1) Change in transmission bearing sound from cold conditions to warm.
2) Occasional grinding type of shift going into third gear.
3) Apparent clutch chatter after the transmission was warm and when starting from a stop.
4) Jumped out of second gear twice while starting up from a stop - transmission was warm.
5) Difficulty going into Reverse when the transmission was warm.
This transmission shop has overhauled countless Getrags and installed numerous NV 4500s in the First Gens. They test drove the truck twice (the rebuilder / co-owner with 40 years of experience) and felt that there were not any significant problems. Three recent oil changes did not show any problems with particle count, brass particles, etc.
Upon opening the transmission the following was found:
1) Input shaft worn by spinning bearing race.
2) All bearings worn and needing replacement.
3) All synchro rings needing replacement.
4) All gears and other shafts, OK.
The point of this message is that these transmissions, (if kept 1 quart overfilled and not significantly overloaded) are very durable but only exhibit subtle symptoms of significant problems / impending failure. The latter is probably their most significant down fall.
Cost to repair was approximatley 30% of the cost of a NV 4500 conversion.
Hope this information might help some of the rest of you.
