getrag input shaft
Things to check while engine is out
93 transmission question
How do I remove the input shaft on my getrag? Transmission is out sitting on the bench just can’t seem to get the input out
Send it to me and I'll take all the unuseable parts off your hands;). Seriously, you have to remove the front retainer (4 botls) and bearing race. Line up the flat spot of the input shaft synchro notches at the 6 o'clock position, on the gears of the counter shaft, and wiggle it forward as far as you can. Then remove the tailshaft housing on the rear. Remove the mainshaft assembly, and then you can slide the input shaft back.
This may not be the absolute best explanation, but hopefully it helps
Daniel
yes the mainshaft has to come out for input shaft removal. You should aquire the getrag overhaul manual that's floating around in pdf format.
HTML:
Heck I'll bet most on this board already have it :-laf
But I'll volunteer... send me an email to
-- email address removed --
And I'll reply with a pdf file ;)
