I'm new to the forum and have recently purchased a 91 dodge for a conversion. Looking for some advice on what I need to replace in my Getrag. I have not rebuilt a transmission before so I'm kind of unsure what is normal wear. First I bought the truck knowing it popped out of four gear right away. It seemed to shift fine into all the other gears. I know have removed the transmission and have gotten the top cover off and have removed the input and output shafts. The 3-4 shift fork was worn down. The 3-4 synchro teeth also look worn down. I'm not sure if the clutch gear teeth on the input shaft are worn or are ok, is there spoused to be a flat spot on the teeth? There was also a chunk out of 5th gear. Also there were shims on the front bearing retainer. There were no shims on rear for the output or the countershaft. I figure I will need bearings as well. Any input would be greatly appreciated.
