getrag shift lever
Vacuum Pump Bearing
Interior trim and rear window latch
I am looking for a shift lever (bolts on with 2 bolts) for a 1990 dodge with the getrag trans -- email address removed --
Are you looking for the stub, or the stick itself? If there's 2 bolts involved, it's likely out of a 93 truck. Most of the pre-93s I've seen had the straight screw in type stick.
DP
