Has anyone encountered a Getrag that is hard to shift, especially from 3rd to 4th gear? This problem started suddenly, trans does not make any noise. Clutch operates normally. If the 3rd to 4th shift attempt does not go smoothly first try the shifter is difficult to get into any gear. I am aware that the shifter itself has some small cracks around the rubber bushing where it presses on to the trans but I don't feel that is the problem. Any ideas? Thank you in advance!
'93, W250, 4X4, Autometer boost and EGT gauges (in the dash)
