Getrag vent hole
Brake light switch/cruise control
Overheating
A while back there was some posts about the shift tower boot on the Getrag G360 having a small slit in it and of it being glued shut, boot replaced ect.
I replaced mine 2X because of this slit.
It looks like the little slit is supposed to be there. Two new boots had it. It appears to be a vent for the trans so there may be a little oil coming out of it.
I don't believe that the slit is for venting as there is a vent in the case just ahead of the shift area. The slit in mine was far from being a clean cut and I glued it shut. There is still a leak that I have to chase down.
Jason's Lil' Mack - 89 D250LE 2WD 5Spd 3. 55 Reg Cab. K&N,"tweaked pump", 3. 5" Exst straight,E&M Custom seats. Bosch H4, PIAA 80W/80W HdLites. Bosch 100W Driving. Bosch 55W Fogs.
218,000 miles (355,000 Kms)
7450 Hrs.
If I remember right, I think that I glued mine also. I pressure washed the transmission off, glued the boot, and its still clean. Just my 2cents worth.
'93 D350 2wd Club Cab 5-speed,133,000 miles,K&N, Amsoil throughout, Borgeson Steering Shaft,Isspro gauges (Tach,EGT,Boost,Engine Oil Temp. )
