Engine/Transmission (1994 - 1998) Getting a 47RE to shift and hooking up on a conversion
Engine/Transmission (1998.5 - 2002) 5th gear nut nv4500
Engine/Transmission (1998.5 - 2002) 6 speed difficult shift
I am new to this site and spoke to a gentleman by the name of Kevin that works at BD Power rebuilding/building their transmission. I have their 1996 Dodge 47RE in a Hummer conversion product. I bought the entire 1996 Dodge truck as a donor vehicle. Anyways I am now trying to get this huge hummer to drive down the street and I have just learned that I should have bought a 1994 transmission with the 47RH making it much easier to hook up. Kevin from BD Power thought you might have a post somewhere with others that may have made the stock 1996 Dodge computer for the 47RE shift the transmission and also make the transmission lock up the torque converter. If you have this link it would be greatly appreciated. I have the entire wiring harness from the 1996 Dodge truck and can not tell which wires that come out of the ECU are to be 12v, ground, go to the speed sensor, TPS ect. Also, this Hummer has Unimog 416 Axles with no speed sensor in the axle. Do you know if the 1996 Dodge truck had this sensor in the axle or the transmission?
Thanks,
Brian
-- email address removed --
