I think what I'll do is tune up the transmission before I get too far ahead. It works good now but I think with BKondolays VB and adjustments, it'll run better and last longer. Bill mentioned something about a resitor required because when with pump cranked up, the TPS gets confused because the pedal don't have to go as far for the sames speeds and it confuses the shifting.
My TC clutch locks up good. I pull a 6k lb billboard and it has never slipped. I guess with trany pressures at max, it should stay there after I crank up the pump. I liie to stay locked up in OD when crusin and 3rd if I'm takling a hill.
Like you said, if you don't hammer down and use the power prudently, it should never slip the clutch.
I just want to be able to cruise over the good hills without having to torque the transmission in OD at 1,500 rpm, cause that's where I end up partway up the those hills. If they get steeper, then I have to drop down to 3rd lockup.
I should be able to top those hills at 1,750 - 2k rpm (100-105 kph) without slipping the clutch. I mean hell, that clutch should hold 6k lbs as it does now when I go flat out into 3rd lockeup.
It's a lot of momney and fooling around just to get what I think is about another 20% more torque to keep me crusing over the hills.
Right now i'm puttin in the pyro. I'll have to read where it goes as I think I'm better off with it after the turbo. some say if the prod breaks up, it might take the turbo with it.
will let you know.
