Thanks for these instructions mechanic - and the instructions I got from others on this site as well. The kdp tab went well. It was out 1/16", but not terribly loose. the 10mm bolts holding the gear housing were far from tight (18ft/lbs is spec, they were not half of that).
I pulled the cam and gear housing, resealed that with a new gasket, retorqued all gear housing bolts with thread lock, installed the cam (no real pits after 180K), put the P7100 back in and the power steering pump, and did the front seal dry like specified here. I used Permetex Ultra Gray and a new cummins gasket for the cover. I won't have a leak down test for a month or two, but at least made progress!
thanks for the help here,
jon
