Wirenut
Okay here is my opinion but keep in mind I am new to Bombing.
Gauges are always first I think most will agree with that.
Next I did the Exhaust, 4" turbo back, no cat or muff.
Next Intake system, I have the Psycotty, or you can go with the BHAF which people are having sucsess with lowering EGT's.
Then I went with a clutch I chose the Southbend Con-O but if your going over 420hp you may option for the newer Con-O/FE wich I believe is rated for over 450hp talk to Peter he will hook up.
Lets see thats intake, exhaust, and clutch, now your ready to bomb the engine.
I have the #10 TST plate wich I believe is the exstream for the 215hp P7100, I slid it all the way fwd along with the AFC Housing
Then I went with the AFC Spring kit and boost elbow.
I just recently added the 4K govenor spring kit and with that you will want to add the 60lb valve springs so you don't float the valves.
With the above mods I am at between 1500 and 1550 for EGT's and right at 40lb Boost.
Next will be a bigger turbo to keep the EGT's in check before adding 370 marine injectors and bigger I believe 291 delivery valves.
I don't know what my current HP is, never dynoed. but will be next month,
I had lots of help with the above from some great members here on the boards people like: My6eats8, brandon, HVAC, Piers, southbendClutch, Psychostroker, and many others.
Good luck,
Scott
