Have had a GFS392 system on my truck for a couple of years, worked great until I think recently. Have the 2 mic kit after the OEM 7 mic canister. Have a electric fuel pressure sensor running to my Quadzilla gauge. Sensor is at the CP3 pump. Picking up only 12-15 at idle and under load empty I can pull it down to 1-4 psi. Filters are all new, 14. 5v at the pump. No odd noises at the pump.
The wierd part is that I can pinch off the return and get 27psi at idle. Only did it for a 10 seconds, didn't want to pop a lid.
I have no drivability issues other than watching the numbers get smaller with more load.
Do I have a failing pump? or a bypass valve problem? Never have adjusted the valve.
Have a call in to GDP, but no return call, I know they don't have the kit any longer.
