Elite1 said:
I have an old (86') Ford cargo Van with a 6. 9 litre diesel. It is very cold blooded... I am not a mechanic, but would like to try changing out the glow plugs. I found a source for 11. 00 per plug. Do I need 8 of them? Where are they located? Is it a tough job?
Fairly easy job, the only difficulty maybe due to having a van (I have never worked on one, so I can't say).
You'll need a 3/8" deep socket for the GPs and a couple of extensions and universal joints to get around the injector lines to get to a few of them. They are on the intake side of the head (the top of the engine towards the air filter/intake and are recognizable by a single 10ga wire going to them.
If you don't know if they have ever been changed out, go ahead and spend the money and replace them all.
Get Beru's or Motorcraft (same plug, different label if'n I recall), the Autolites are generally regarded as garbage as they are known to swell and break off in the chamber = bad.
Also as mentioned, the best practice is to bring each cylinder to TDC to avoid the tip (should it break off) from going from the prechamber to the combustion chamber. The idea is that if it does break off, you maybe able to remove the injector, put a shop vac to the injector hole and compressed air to the GP hole and suck the thing out of there. Not sure what the success rate is, but if you lose a tip into the chamber, you're looking at pulling the heads off to avoid destroying the engine.....
If any issues crop up while changing them out, post back or go over to
http://forums. thedieselstop.com, the guys in the 6. 9L board will be able to walk you through any issues. Plus they're a friendly bunch.....
