Glow plugs
Battery time
Diesel police car
Had a guy try to tell me , the newer Cummins have glow plugs??? I told him, NO. Am I correct? Haven't kept up with the later CTD. TIA jps
the day a Cummins has Glow plugs will be the same day u see dinosaurs roaming again LOL and i don't see that ever happening, probably a ill informed person who likes to think they know what they are saying. .
Never figured out why Ford uses them either, those things are a weak point in the engine. .
Yep. . they are a weak point in ANY diesel engine... they burn/short out on a regular basis, and I have personally witnessed what happens when one breaks off and falls into the cylinder of a d-max at 3k RPM @75 mph. It totally train wrecked the entire right bank and the turbocharger.
What would glow plugs cost to replace anyway?
My brother-in-law has a 03 Ferd and his went out... now it won't even start when it's slightly chilly outside.
7. 3 glow plugs are like 10 bucks each,they seem like a crappy design with all the under valve cover harnesses and all that.
Rock auto has the motorcraft glow plugs for 10. 99 each and you can pick the relay up for like 30 . takes about 3 hrs to change glow plugs ,1/2 hr for relay be a a good time to check wire harness under valve cover too
