GM 350 dist wiring help
Honda Gyro
2008/2009 Subaru Forester?
Helping my dad with a 50 merc street rod were doing a 350 gm conversion (used motor) im stuck on the dam distributer wiring. The dist is mid 80s and has 2 harneses. :confused:
1 with pink,black and dark brown.
1 with green, white,black and brown. (black and green are wire nutted together by last owner)
What i need is which color gets 12v hot off key and which color gets ground to test run the engine?
Is this a HEI unit? does it have a coil separate from the distributor?
The ground is through the distributor. There should be a power positive wire and a tachometer wire. Use a multimeter on continuity , put positive lead on one of the wires with the ground on the dist. housing and slowly turn the distributor. You should get continuity on the positive wire.
I hope this works. I do know that the dist. grounds through the body of the dist. itself.
D
If it is an HEI, an Very large cap with the coil in the center, the wires come out to one side, underneath the cap. They are male spade connectors. Hook a wire on the connector that says Batt.
D
