GM V6-53 fuel pressure ?
help on 03 2500 needed
Mercedes Diesel?
PUMPERDUDE
I want to put a fuel pressure gauge on the secondary fuel filter housing. What does the pressure run?What range gauge should I use?Thanks
I'm not quite sure but I was told that at full scream they develop about 50 psi. I also think it is marked on the transfer pump along with the direction.
Thanks... ... . Full scream,you got that right. Its in our aluminum crewboat. . Better wear your ear plugs...
GM 6V-53
PumperDude, You can look at 50-70 psi at 1800 rpms, most marine 6v-53's have a standard output fuel pump with 1/4" gears and . 070 restricted orifice, where as 6v-92 have a high output pump with 3/8" gears and a . 080 restricted orifice and run at 50-70 psi. Love those Jimmys... . they can be turned upside down and continue to run:D
Dave
i like the versions of those 2 cycle diesels i work with... 16v645 and 16v710 :-laf and yeah, they screem a bit when you bring them up to just before the overspeed trips...
