2nd Gen Non-Engine/Transmission Go Here To Get The Bhaf Heatshield Template
Due to the extreme amount of PM's I've been receiving requesting the template for the heatshield... ... ... ... ... .
23 last year
15 so far this year
Im still not sure where people are getting the info about me having the template lately ... ... ... . but its like wild fire :D
... ... ... ... ... ..... I started this thread just to let everyone know it is available at my (UNDERCONSTRUCTION) WEB SITE
I 'm glad to help out when ever I can I've even sent a printed out copy all cut out and taped together to florida :)
KEY INFO FOR THE SHIELD.....
DRILL THE HOLES 1/2 inch or the shield may rub the AC lines
Use 1/8 INCH STOCK
HEAT SHIELD TEMPLATE CLICK ME
here are the filter part #'s
WIX 42790
Donaldson B105006
Baldwin PA2820
Hastings AF1012
DONALDSON ECB105006
Fleetgaurd # AH19037
Napa # 2790
Carquest # 87790
John Deere # PMAH19037
Big A # 93790
CATERPILLAR# 3I0005
FLEETRITE # AHR819037
LUBER-FINER# LAF2531
OUTERWARES
P/N: WR3325-105BL-$30. 00 WR=water resistant BL= blue
Other colors avalible
1-800-967-3450
just tell them its for the BHAF - napa 2790
Heres a small collage I put together to aid in construction...
That should help some people out
Later ;)
DM
Cool, thanks for the write up i have been planing geting gauges as soon as work and money pick up. I have been debating weather a not to do them my self . Good info :) Bkenny
Got to say thanks
Thought I'd throw in a Thank You for the template help. For those of you who need a heat shield due to installing a bhaf, this is the one to use (imho). Dieselminded was kind enough to help me through downloading problems for the template that is on his website. Easy to make, cost effective, fits properly and works.
Thanks Again.
wouldn't it make sense though while useing the heat shield while having the truck pushing more fuel than stock and turbo psi in the 30 range, couldn't that make your turbo overheat with the heat shield on it? i have the bhaf but i have so far refrained from putting the heat shield on. i would think when useing the heat shield you would be required to use a cool down timer or something. i thought heat was bad on our turbos.
The Heat Shield is not on the turbo
I run 45 psi WOT 5x5 and Ive never had a problem
I haul under constant load also with Same results
EGT"S go down also
DM
New page is up as well as A short guide I threw up on my site check it out
its on my performance mods page
this should clear some things up for new members
later
DM
HEres a New Direct Link to the Guide/Template on the home page I have A Contact to a Fabrication guy and currently he has Shipped the templates all over the US he supply's hard ware also ... I get absolutly no kick back from the sales When Ever I get a hair brained Idea he Welds/Fabricates it for me and my truck for free so thats my kick back. .
So Who On TDR has got a Shield From Tad ???? Satisfied ???? Recomend ????
Heres the new link guys
http://3d.otisnet.net/toppage2.htm
And heres the contact for the fabricator he can make it out of just about anything you would like
tmurata@ohiohills.com
Thanks
DM
