I am experiencing a high frequency vibration through the accelerator pedal and gear shifter during acceleration and at cruising speeds. The vibration feels like your foot does when it goes to "sleep". It seems to be more noticable under a "load" for instance accelerating to pass another vehicle. This condition exists pulling a trailer or running empty. Also, the vibration occurs between 1700 RPM - 2700rpm with and without a trailer. Even at idle I compared the gear shift vibration of my truck to a friends 96 and mine vibrates quite a bit more. I have had the tires balanced about 3 different times with no difference. I have checked the u-joints, ball joints, everything is tight.
The vibrating truck is:
1997 4x4 Extended Cab Long Box
Manual Trans, 94K miles, No modifications
Owned the truck since new.
Your help is greatly appreciated.
