Go pedal/ No go
no muffler
Aeroturbine Muffler revisited
Just checking to see if anyone else has had this. At about 30 degrees outside when I started my truck, I let the oil pressure come up and put it in reverse, pushed down on the go pedal and nothing. I thought maybe for some reason I was steppng on the binders-NOPE! I then put the truck back in drive- correct pedal- still no throttle. I stop to contemplate what just happened and decided to let it idle off of the ice I was parked on so I could safely check it out. Put it in reverse idled backwards - then to drive and what do you know I know have throttle. ??????????????????????
By the way I still have the engine knock I mentioned earlier. I think some of you might be correct about it being an injector knock of some sort. Gonna try to get it to the dealer today.
The Flash!
I have never experienced this before with my truck. Is it a cold weather thing, or can it happen at any time. I have the 47RE trans, and was wondering if I need to set up a time for the dealership to do the flash, or not. I hate for them to mess with anything as long as it is running fine and shifting fine. :eek:
