:{ This is a problem I have currently with my 89 250 auto 2wd, help. When cold below 50deg and upon first start up in the morning ,the accelorator pedal will not advance, its rigid . After driving one block it releases and operates normal. The grid heaters are working and the thermistor checks good. Could the fuel heater have any effect on this problem? At present I still do not have guages on this vehicle however, the RPMs seem to be in spec. and every thing else operates normal. The guages are on the got to list I just had to install on the other two trucks first because I use them more often . Thanks for your help again as you have done so many times in the past. What a great org. Ken.
