larryq
It looks like my stock Michelins are ready to be put out to pasture.
The truck has almost 60,000 miles now... so nothing to complain about as far as how long OEM tires lasted...
The truck came with 245/75/r16 and I've decided to go to the 265/75/r16's tyhat come on the newer trucks now.
I'd like to go straight to a 285's but that's a No Go... .
The truck just BARELY fits in my garage as it is now with the 245's.
The 245's have a rolling diameter of 30. 5" and the 265's have 31. 7.
the 265's additional 1. 2 inches will only net a lift of . 600... . (Plus or minus the new thread depth)
Right now I've got a 3. 5" headspace between the cab clearance lights and the header of the garage door... . so I should be ok.
The spare tire (which has never been used) will remain the stocker 245.
Should I need to use it when 265's are all around will I have any trouble???
I have an "Open" differential in the back, no L. S. for me thank you.
And the truck is a 4WD... ...
I would think that if I got a flat in the back... No Prob... ...
But it's the front I'm worried about.....
If I get a flat in front, will I have to swap a rear 265 to the front and put the 245 spare only on the rear of the truck???
I'd see the use of the spare was only in an emergency... and would only keep the 245 on long enough to get to a tire shop.
What Say Ye???
Thanks
Larry
What Say Ye???
Thanks
Larry
