Do you know WVO is NOT bio? Take the WVO and convert it to fuel with Transesterfication process and filter it very well as the last stage.
Just to let you know that in Calif the BIO that they mix with Petro Diesel is WVO and new unused oil that is brought to the fuel racks in trucks, load after load of it everyday. I believe but im not sure but they use animal fats in their process for commercial use.
We use 100% canola oil (used) and then run it thru progressively better filters, then use that to make our HOME BREW BIO DIESEL.
http://thebiodieselstore.com/biodiesel-processors
http://thebiodieselstore.com/biodiesel-processors/80-gal-freedomfueler
Our ONLY problem that we have had with this system is the size of it, we should have gone to a bigger system because we cant make enough to provide what the entire family can use.
IF IT AINT BIO DIESEL THEN WHAT IS YOUR BIO DIESEL MADE FROM?
What is Biodiesel?
Through a process called transesterication, vegetable oil is refined with an alcohol in the presence of a catalyst to produce a fuel called biodiesel. Biodiesel is cleaner burning, nontoxic, and safer to use than petroleum-based diesel. Biodiesel meets the criteria set forth by the department of energy and is a registered alternative fuel with the EPA.
The question about what fuel lines to use, when my Lift pump took a dump on me and the factory fix was the in-tank pump is when I really went to bio, I installed an AD 100 Lift pump and ALL NEW SOFT LINE that was Bio compatible. I have had very little problems with the filters plugging even when I have ran Dino Diesel all winter and then go to the BIO in the warmer months, at that time I run a tank of B100 ( my tanks are 100 gal normal tank and the AUX tank) and watch the pressure gauge. When and IF it starts to rise that's when I change my filters and run the B100 for the rest of the warm months, then when winter comes and I go back to Dino Diesel I watch the pressure gauge and if need be I would change them again but it never seems to change when the change is from BIO to DINO only from DINO to BIO, I would guess that in the time I run the Dino Diesel the crap comes back to some extent and the change from Dino to Bio cleans the system again.
BIG
