Wow I dont even know what to say. Why would fuel be piped into the turbo? Ok I have a bunch of questions but they are actually for the service writer and "mechanic". He doesnt deserve to be called a mechanic let alone a tech. When I worked for dodge we didnt care what you had on the pickup as long as you were cool and werent pushy with us ( only had a couple of people that deserved to get denied work)......
I have been totally relaxed and even compliant......but that is quickly changing.
Chris- was the dealer you took it to located on RT.1 in Lawrencville? Sounds like the same clowns I brought my 03' w/ speed transmission and said that the transmission was cracked due to it was a "plow and salt truck" (see my old transmission cracked?) thread. Total B.S! I had the transmission removed and sent it to Standard Transmission in Texas. Transmission was not cracked only the boot and the top where the stick shift had worn away! While the trans was at Standard had them install the rear lube kit they offer. Truck and transmission have run great since then! Those guys are plain out thieves!!!!! A very good shop that does injector testing is located in Moorestown,NJ Garden state Diesel. They rebuilt my injector pump on My 92' These guys know what they are doing!856-914-9797 ask for Rick. Good luck. Frank
Same exact dealer!!!!! To call these guys thieves would be an insult to thieves everywhere.
I am saving this for future reference, so I can LMFWAO every time I think I have problems. All I can say is, OH MY............
No, if you are holding 7-10 psi at the CP-3 inlet that isn't causing the smoke, rough, idle, etc.
No, it is impossible to tell from cylinder contribution tests what size the injectors are. It extremly hard to tell if it is a performance injector even with it on the bench. These clowns couldn't tell a CR injector from 12V injector if it was in front of them.
No, they would not know a 1200 cc injector if it bit them on the back of their front. They obviously don't know a propane kit from an oil bypass system so it follows they probbaly don't know a lot more.
Yes, a competent operator can print out the contribution tests, kill tests, etc. It follows that these so called service people are so incompetent they can't even figure out how to PRINT.
I would not trust them to wash the truck let alone work on brake lines, fuel pumps, or anything else that is remotely connected to the vehicle running and driving.
I would have driven the truck home, bad brake lines and all, cuz that bunch is NOT to be trusted with anything. I would not let them put the in-tank pump in because they likely screw up the install then blame the "race" truck for a failure.
Sorry for your luck, and, you should have taken your truck when you ran.
Since this is an 04 and they may have used the DRBIII there is no way to print. I suppose they could have taken a photo of the screen. If they used the DRBIII emulator on wi-Tech they could have used the screen print function but most dealers do not have printers on all the computers in the service department.
Thanks to everyone for the advice, and ya know what I dug deeper as a result of the advice. I went back up to the dealer unannounced (didn't call first) right after reading Cerb's post because deep down I had the same sentiments about pulling my truck out of that shop. I didn't because of the brake line issue and the its 20 degrees outside and I've got no where to tackle a job that involves dropping the tank.
My last conversation with the service writer on Friday night at 5pm indicated the part (not sure if the brake line or fuel system upgrade) was being overnighted, the truck was apart and I'd have the truck back today. I get up to the dealer and look in the yard through the fence, only to see my truck is parked in what looks to be the same exact spot? So I'm trying to be glass half full, and think maybe its done? Because other wise someone is lying to me and that ain't gonna go well. I go inside and the service writer recognizes me and says "whats up?" I say what's the status on the truck? he says lets go check with the tech, and proceeds to walk me out onto the shop floor. I'm thinking maybe this is good, job must be done, the truck is outside? So now picture this, its me, the service writer and the tech face to face to face......
Service writer: What's up with the 2004 Ram with the brake line and fuel system upgrade?
Tech: Nothing? The part is on backorder we can't locate one.
Me: (Looking directly at service writer) You told me the part was being overnighted? What the hell?
Tech: No overnight, no part, have to find a dealer that has one in stock first, AND that is willing to give it up.
Me: What!?!!! This ain't gonna work, I need the truck.
Remember service writer said truck was apart to me on the phone. Now I ASSUME the truck is apart and the tank is out of it sitting in the bed waiting for parts.
Tech to service writer: We need to get this guy a rental (not a courtesy car, but a rental).
Service writer: We don't have 3/4 ton 4x4 rentals?
Me: I don't want a rental, I want my truck fixed!
Service writer: Uh ok, I'll fast track it and get it in the shop immediately.
(I'm thinking how are you gonna do that if the part is on backorder??????)
Tech: The part is on backorder, like its not available and the truck is NOT APART YET. I didn't want to take it apart until the all the parts arrived? Can't afford to tie up a bay.
(I completely understand the tech's point of view, but the service writer and him need to get their web of lies in sync. I honestly think this thing is 100% on the service writer at this point.)
Me to service writer: What?! I have to check a few things and see what my options are at this point. I walk out.
So my phone dies (of course) and I realize my charger is in my truck, perfect, its a reason to go into the yard and take a close look in good light to see exactly what the hell is going on. I check in with the service writer and ask for the keys so I can get some things out of the truck, phone charger etc....he says go ahead, it should be unlocked. I climb under the truck to find that the brake line did indeed fail. Bad luck. Fortunately nobody got hurt. But the line that failed isn't the metal line, its the hydraulic line. The crimped band on the flexible side of the line must have been faulty because it is completely separated, and allowed the "rubber" side to be blown off from brake pressure. I can see the metal stem of the fitting still there. So now I'm like WTF?, the metal line doesn't need to be replaced, the hydraulic hose needs to be replaced. I storm back into the service area and tell the service writer to grab the tech and meet me at the truck. I show both of them and they agree, the metal line is fine, only the hydraulic line is faulty. They say it was dark and they couldn't see it clearly when they first looked at it. At this point I demand they drop whatever they are doing, pull my truck in and get to work on the it. So now we are back in the office and I'm like you guys are not authorized to do any work other than R&R the hydraulic line at the rear. Not fuel pump, no dropping the tank, nothing.
I was of the mind to pull the truck, but screw them, why should I lay in my driveway in sub freezing weather with more bad weather headed my direction fighting with a brake line? I'm gonna hold their feet to the fire and make them work for it. If they screw that fitting up, I'll just pull the truck out and piece in a new line from somewhere forward of the tank to the rear transition point.
I am not even sure they even had the truck in the shop or ran injector diagnostics at all, let alone if they have the ability to print reports or not. Unfortunately, the brake line failed, and maybe they didn't see it was the hydraulic line side that failed, but they just started spinning a web of lies and saw $$$$ and that is total BS. Dodge should be ashamed if this is how their network of dealers operates. Once the truck is back in my possession, the letter I write to the dealer service manager and copy to RAM and the BBB, they'll be lucky if they still are allowed to have a dealership, let alone a job.
Stay Tuned......
