Gonna dyno again!!!
GTP38R PSD Turbo
HTB2 wastegate rod position/stuck open?
Hey all, just got done putting the Vulcan big line kit on, along with a Holley Blue pusher. It buries my 16psi Westach gauge, so it is time to order a bigger one. While putting the fittings on the factory lift pump, I noticed the MAP sensor plug hanging down :{ The Comp never got hooked up again after the VP died. So when we were all done, we took it for a ride. AND WHAT A RIDE!!! Oo. I can now black out two lanes of traffic with thick black smoke. For any of you that were at Kauffmans, all I got was a puff of black smoke, now it is pouring. And I can hit almost 38 lbs of boost if I hold it to the floor. I know that is too much for a HX35, but it is now running like all the mods should make it! I will be back for the Spring Fling!! :-laf
Tiny smoke is real good :-laf will you be at the spring fling :D iam hoping for in the low 500 hp this time its just my tow rig :-laf :-laf
