I have installed a "Mystery Switch" to lock the torque converter clutch that uses a 15 psi Hobbs pressure switch to open the connection to ground when you slow up (less than 15 psi boost). The Normally Open (NO) pressure switch is in the electrical line from the manual Mystery Switch to ground. Thus, the Mystery Switch provides another ground for the torque converter clutch only when the boost is over 15 psi and cannot keep the TC locked at less than 15 psi. .
I used a Radio Shack Double Pole, Double Throw (DPDT) switch (on-off-on) to provide three functions.
Up - TC lockup with boost over 15 psi and stock performance under 15 psi.
Center - No TC lockup available (TC lock off)
Down - Stock TC/transmission operation.
The wiring for the DPDT switch with the terminals for each pole being numbered 1, 2, and 3 with number 1 on the top.
The wire between the PCM and the transmission is cut and spliced into the DTPT switch as follows:
From the PCM (stock ground) a new wire extension is connected to Pole 1/terminal 1 and Pole 2/terminal 2.
From the transmission a new wire extension is connected to Pole 1/terminal 2.
A new wire is connected to a new pressure switch to Pole 1/terminal 3 and Pole 2/terminal 3.
The other terminal of the Normally Open (NO) pressure switch is connected to ground.
I connected the pressure switch in the line to my boost gauge with a tee.
Note, this is probably only recommended for stock or mildly bombed rigs. DTT/Bill Kondolay offers a Smart Controller that unlocks the TC at high power levels to protect the TC clutch with very high torque engine modifications. If you only want a Mystery Switch for pulling a trailer up grades without the TC unlocking and building heat this should work without the worry of forgetting the switch and damaging the TC clutch when you come to a stop with the TC clutch locked up. Goof-Proof.
