Goose neck ball mounting
Need Pics Of '03 3500!!!
Does anyone have any info on drilling the frame on the '03, in the past I've built numberious custom hitch's, for myself and my ranchin' buddy's. I would like to know the do's and don'ts of the hydro-formed frame.
I am interested to
I had to stop at a dealer to try to get some stuff and took a look at a 2500 swb I had seen the engine and interior before and had just not look any farther ( not interested in buying one) but I looked in rear wheel well and there are no holes for gooseneck for 5 wheel plate mounting. That makes things a PITA to mount hitchs doesn't it? It seemed they weren't thinking about that part of the truck use.
There is a problem! DC says you shouldn't drill or weld on frame, will void warranty. B & W has a turn-over ball mt. for the 03's, my dlr. installed one yesterday. The dlr. is going to install my 5th wheel hitch Mon. , the shop foreman said he has the info. The DC rep was there and said they, (DC)definately have a problem. Will find out more Mon. , I hope! I called Reese Tue. and they knew nothing about the no drill & weld, and they make the OEM receiver hitch for DC.
Larry
That would be brilliant, eh?
"Yeah, we done gone built us a big'ol truck that can tow a house..... ooops, we forgot you might need a hitch for that!"
I'm sure DC will figure it out, but in the mean time, all you can do is shake your head... ...
I remember seeing two 2003 Duallys towing Goosneck trailers with what looked like large concrete blocks on the trailers. This was 2-3 months ago and these trucks were obviously test mules for Dodge/Cummins. Wonder how the gooseneck hitch was installed?
B&W hitch
Yogi,
How come you're not using the B&W companion 5th wheel hitch? Did your dealer have to drill or alter your frame in any way to mount the turnover ball? Inquiring minds want to know.
Fireman
Well guys I guess if DC doesn't come up with something I'll have to. I've got a couple of clamping style ideas that wouldn't involve welding or drilling frame. I'm still in the r&d phase though. If I brainstorm up a cool idea I'll let you know.
Fireman 56, the ball mt. wasen't installed in my trk. , on another trk. , I have a Reese 20K 5th wheel with the ball mt. attachment. B & W has a mt. for the 03's, so you don't have to drill or weld. I didn't see this, tech. told me he installed it. I'll let ya know what I find out Mon. , I won't be there when its installed, but I'll have them draw me a schematic on how they did it.
Larry
I would not get to excited about not being able to drill or weld the frame. Many class 8 trucks say the same thing. I would say in a matter of days the reputable hitch companies will have no drill or weld mounts ready to go. I would call them and D/C ASAP to ease your mind.
FWIW, I was poking around at a different local Dodge dealership than my usual one (I can only go there on Sunday because they're so sleazy), and there was a sold green 3500 quad there, ready to go, and it had a reese 5th wheel hitch installed in the bed. Looked like a used hitch. Couldn't see very well how it was attached (it was a 2wd so it was pretty low).
To be honest, I think you're all panicing. Dodge makes a big deal about how these trucks can tow heavy. They tested them by pulling a large concrete block on a gooseneck trailer. And I bet that they are still only rated to tow 10,000 lbs with the bumper pull hitch. Therefore, to achieve their 16,000 lb tow rating they must be gooseneck/fiver compatible. Maybe it will require different mounting than we're used to, but that shouldn't be a big deal.
I for one am not worried
I would not be worried I am sure someone has the anwsers but I t just seemed strange to me not to have predrilled holes in the frame for easy of installs that d/c should know are going to happen alot. When I posted I figured some one already would have a truck with a hitch in it and could tell us how they attached it to the truck that is the first truck that I had seen at a dealership and just figured that I would check it out I hope noone is panicing do to my post!
craig
