Gooseneck and 5th wheel
surge brakes
Cdl
It is time to upgrade my hitches. The question is to those of you that have both gooseneck and 5th wheel. What systems are you using? And Pro & Con
Thanx, Tom
I prefer a GN, easier to remove/hide when you want to use the bed.
A 5th wheel is easier to back into and will spread the weight a over a greater area, which shouldn't really matter unless you've got way too much weight on the truck.
Thanx Bill
What I need to know is about being set up for both. I would just prefer the gooseneck myself. It looks like I am going to be pulling a bunch of different trailers of all types.
Tom
I have the Reese rails in the truck. They stay there all the time. I can switch hitches as to which trailer I want to pull. The gooseneck or the 5er by just undoing the pins and re-installing. Some people don't like the hassle but this works for me.
Originally posted by klenger
Come on Rusty, tell him about the Turnoverball or what ever it's called.
OK, here's a typical thread discussing the B&W Turnoverball GN hitch. LINK
If you check their website HERE, you can see the gooseneck and companion RV (5th wheel) hitch.
Rusty
I like the Atwood folding gooseneck better. You can raise/lower it without grabbing a greasy ball to turn it over.
Eric
I also have the Reese rails and I swap back and forth between
a 14K 5er head for my 5th wheel and a homeade plate with a
2 5/16 ball that I duplicated the feet that pin into the rails, for
my gooseneck. Works great. Now I am just hoping to put
my these rails out of my '02 into my '03.
Eric
