If you have rails in your bed and the draw-tite plate with gooseneck ball as your gooseneck hitch -- WARNING -- it WILL come apart eventually. The only thing holding your ball in place is a little C clip at the base of the ball. Even if you are careful about vertical load that clip will eventually snag the lip on the bottom and pop clean off. Then the next bump you go over will seperate your trailer from your truck.
Ask the crew that helped save my butt at the pull in Platte City. Went over a little ditch in the parking area; enough to lift the trailer slightly; and ker-pow big hole in the bed.
Went to investigate and were looking for the nut that came off and WT? just a CLIP? The gouge on the bottom side of the plate where the clip caught before popping off indicates it came off while rotating (not vertical lift) and the minor bump is just where we seperated.
Thank god it was in a parking lot.
And it punched thru a clear spot in the bed (nothing under it! missed everything!).
And there were EXCELLENT diesel head welder GODS there to help -- Hey Nathan and Justin and everyone there that pitched in -- the Nebraska/Missouri/Kansas crew -- you guys ROCK.
It landed on the security chain going thru or it would have dropped until feet touchdown or bed rails; whichever came first.
So many things to be thankful for!
But Draw-Tite is going to catch some heat. If they won't work with me my insurance company will be sucking their blood dry.
I believe this to be a very good setup now that it's welded solid top and bottom to the plate. So if you have it -- weld it!
