Details here: TDR Privileges
If you don't get a module or you decide to get a downloader then you need a boost fooler. As far as I know we are the only ones making one and they are supposed to be available next week.
These are very inexpensive and will allow you to make full use of your injectors by keeping the wastegate closed. You will be able to make in the neighborhood of 40psi or maybe a little more. Doing this will also lower your peak egt's some. I am not sure what power gains you will see but I would say a good 20hp at the upper levels.
transmission work would be a definite must if you intend on pushing more power. A fairly hot box would really make a difference and not cost to much either.
Running the Dr. Performance 100hp injectors... no dyno... just seat of the pants... OMG. Oo. Big differnce... need more air and timing, fuel pressure too.
