Got 150 instead of 95??
heater grid eliminator
NV5600 Transmission Rebuild
I had the new FASS installed just as a peice of mind (got 90,000 miles). I figured I was getting the 95 (like on my 04. 5) but as I was filling out the warranty card I found I got the 150. I usually run in stock mode, will the 150 create too much pressure or will it be o. k...
How do you know if the pump is 150 or 95? My warranty card had 150 on it also. But I have a 95gph pump like I ordered. It has been almost 2 years now, but there was a stamped letter on the pump or housing that identified whether it was a 95 or 150. I can't remember what they were right now, memory is fading fast. I will see if I can find a post or info that I had from back then.
The pressure should be determined by the pressure spring, mine is at 18psi and that is certainly not a problem.
