Got a few issues since replacing the headgasket on my truck. Cant quite get them figured out.
1. ) Idles slightly rough. Some say its no big deal and its due to the injectors I installed and that its normal, some others say no, I have somthing else wrong. I installed a set of Jammer 4 8 hole tips. Had the tips installed at a local shop and pop tested as well. Put them in after doing the headgasket/o-ring/stud job a few weeks ago. I did have some diesel fuel leaks around the fuel delivery lines at the head, but I took the lines off, cleaned them up and re installed them, looks like it might have cleared that up, but I havent cleaned all the fuel off yet. Still idles a little rough. When the AC is on, and the pump cycles, the engine slightly stumbles for a milla sec, then goes back to normal... well sorta normal. Its hard to explain.
2. ) If I park at an incline (nose up hill only) for a few hours, it has a hard time starting, I have to crank it for a few seconds before it fires off. It only started doing this after the headgasket replacement. I have looked for leaks and cant find any at all (except for the delivery lines I mentioned above, and beleive I fixed that. ) Could it be I have a leaky Injector delivery tube? Could this cause this, as well as the slighly rough idle?
What I have done, replaced all filters, and cleaned up the fuel line fittings, polished them up nice again, as they had many little spurs on them. I am running the Vulcan Big line kit with pump relocation, no leaks anywhere and I get 15+PSI at start up. The fuel canister in the tank is gutted, if that makes any difference. Valves are all within spec and all studs are still at the correct torque ( just checked them yesterday )
If ya got some other ideas, I am all for trying them!
Thanks!
Thanks!
