got a guy who is asking about reprograming
reprogram speedo
What could THAT be?????
Has anyone been successful in reprogramming the 255 Horse engine with the new 305 Calibration File using the DRB3. I have a 305 vin and calibration number but the 255 wont accept the files. Can you blank out the Jtech module and reprogram it?
It might be possible. Maybe. I mean, they both use the same CM845 engine controller. But what about the difference in piston cooling passages/nozzles with the ISB305? If you successfully reprogrammed a 255, might you not burn up a piston?
You'd have to blank out the JTEC module and the CM845, plus probably the transmission module if it's an automatic. I can't speak intelligently about doing this.
