Installed 2 FP, 2 EGT, Boost and Trans temp gauges yesterday
FP problem... Hewitt FP Gauge w/ isolator. I used the hose from Genos to tap into the schrader valve on the injection pump.
Which connects to the isolator...
The isolator tubing runs into the gauge mounted in the A-Pillar.
Air bubbles are present in the tubing. No kinks that I can find, but I also do not have any pressure! After a short drive, the gauge indicated about 1/2# of pressure. I tried both hose to gauge combinations on the VP port with the same results from each gauge. Anybody have any ideas for me to check out?
The pre-filter banjo has a plug instead of the schrader valve as I expected so I only have one gauge hooked up right now. Anybody know where I can get a valve that will fit?
The trans temp gauge is also not hooked up yet as the sender manifold is a different size than the sender that I have. I should have that corrected in a few days.
btw, many thanks to the guys at the GLTDR Wrench Day that helped me out with this project.
TIA,
Bill
TIA,
Bill
